tire pressure for Bridgestone tw203/204
Results 1 to 10 of 14
Like Tree14Likes
Thread: tire pressure for Bridgestone tw203/204
    Member jim's Avatar
    Indio, CA
    97
    Stock tires 22 psi front, 25psi rear according to the manual. These Bridgestone tw204, tw203 have a 33psi on them, both rear and front. Any idea which is correct for these new tires?
    Ken likes this.
    Join Oathkeepes.org
    Because Home Land Security Begins @ Home: BPAUX.org
    Guns only have two enemies: Rust and liberals
    Feb 2013
    Missoula, MT
    801
    Run what ever PSI feels good. Better question: What is the best oil?
    Ken likes this.
    Member jim's Avatar
    Indio, CA
    97
    Quote Originally Posted by fishguy View Post
    Lol. I agree, it could have been better or even the best but its still a good question.
    Ken likes this.
    Join Oathkeepes.org
    Spokane, Washington
    13,855
    18f 18r unless you are over 200lbs. If you are more, 22f 25r and then adjust accordingly
    Ken and Peterb like this.
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    480
    I wouldn't go any higher than the 22 and 25. My first tire I had Yamaha mount and I thought something was wrong with the bike. It felt like I had to struggle to keep it from tipping over. The dealer had put 32 or higher, it was so long ago. When I got home I checked air pressure and deflated them. It was then rideable again . It was very unstable and dangerous with over inflated tires. My opinion.
    Member jim's Avatar
    Indio, CA
    97
    CYCLE GEAR mounted them and put 45psi rear, 35psi front. Is the stock tire pressure any different then these tw204? Just wondering because its more of a road tire.
    Ken likes this.
    Join Oathkeepes.org
    Member jim's Avatar
    Indio, CA
    97
    Quote Originally Posted by Ken View Post
    I may not have asked the question correctly. I had the stock tires changed out for these tw204, tw203. They are more of a road tire then the stock tires for the tw200.
    Ken likes this.
    Join Oathkeepes.org
    Ken
    Ken is offline
    Aug 2016
    Houston, Texas
    480
    I have the same ones on mine and run the 22 and 25. Higher you are apt to run the center down while the rest still has more tread.
    Peterb likes this.
    Member jim's Avatar
    Indio, CA
    97
    Lol, I had the same problem, felt like a bicycle tire and out of control taking turns. I'll take your advice. Thank you... by the way, how do you like the tires?
    Ken likes this.
    Join Oathkeepes.org
    Ken
    Ken is offline
    Aug 2016
    Houston, Texas
    480
    On the street they are great, no issues. I like the kind of racing slick look. I kind of used to like the 4 wheel drive hum and the looks I used to get from the mudders though. These last much longer on the street and don't slide as much. Beware of wide paint strips on the street, pedestrian areas, stop light paint bars etc. I slid on those a few times.
  1. TW203/204's tires, like em?
    By StevieP in forum Performance and Customization
    Last Post: 06-06-2016, 05:10 PM
  2. BRIDGESTONE TW203-204 TIRE PRESSURES
    By thumper in forum Technical Help
    Last Post: 10-30-2013, 07:53 PM
  3. installing Bridgestone TW203/204's difficult?
    By GlassAnkles in forum Technical Help
    Last Post: 08-28-2013, 07:40 AM
  4. Replies: 2
    Last Post: 07-05-2013, 11:59 PM
  5. TW203, 204
    By Dark Sol in forum Performance and Customization
    Last Post: 04-27-2011, 05:54 PM
