Removing the plug from the pilot jet mixture screw
Results 1 to 4 of 4
Like Tree4Likes
  • 1 Post By Deepseadan
  • 2 Post By Welder
  • 1 Post By TopPredator
Thread: Removing the plug from the pilot jet mixture screw
    Junior Member Hambone's Avatar
    Apr 2014
    Sour Lake, Texas
    25
    Just wondering if there's a preferred way to remove the plug from the pilot jet mixture screw to minimize the chance of causing potential damage and screwing something up.
    Senior Member Deepseadan's Avatar
    Sep 2016
    So Cal
    256
    In a few days I'm going to remove mine. On the few carbs where I've removed the plug I've drilled a tiny hole and threaded a screw into the hole just a tiny bit and pulled it out. Although if I remember correctly, I think I did my first carb plug by drilling a small hole and using a 90 degree pick to pry it out. Both methods work fine but the screw is probably better.
    Hambone likes this.
    Current bikes 2016 KTM 500 EXC, 2016 Yamaha TW 200
    Senior Member Welder's Avatar
    May 2015
    PNW
    110
    Big thing is be patient while drilling and don't push too hard or the bit is gonna ram into the adjustment screw head underneath when it breaks through, dickering it up.
    Peterb and Hambone like this.
    Jun 2014
    Bel Air Maryland
    3,125
    I used a deck screw on my 2006 without drilling. The 88 plug seemed thicker so I used a drill bit then used the deck screw.
    Hambone likes this.
    Hello New Members. Hidden Content Please update in (Settings) (Edit Profile) (Location)where you are from. The best part of our Forum is meeting new members.
    TW 2006 Ruth
    TW 1988 Black Widow.
    Rick
  1. Pilot Jet vs Pilot Screw adjustments
    By Tee Dubbs in forum Technical Help
    Last Post: 05-23-2016, 05:04 PM
  2. Replace Pilot Jet Screw Plug?
    By Devils Advocate in forum Technical Help
    Last Post: 05-16-2015, 08:31 AM
  3. Idle (pilot) screw plug
    By Explorer in forum Technical Help
    Last Post: 08-27-2014, 10:23 AM
  4. pilot/air/idle mixture screw
    By PalmStateCrawler in forum Technical Help
    Last Post: 11-03-2012, 09:41 PM
  5. Pilot Jet Screw Closed
    By JD_ in forum Technical Help
    Last Post: 04-11-2012, 08:32 AM
