Using a jack/lift
Results 1 to 5 of 5
Like Tree12Likes
  • 1 Post By revtbob
  • 2 Post By Bronxborn
  • 7 Post By TW-Brian
  • 1 Post By phelonius
  • 1 Post By drstimpy
Thread: Using a jack/lift
    Junior Member revtbob's Avatar
    Jun 2016
    18
    Using a jack/lift
    My son gave me a motorcycle jack/lift that he bought and couldn't use on his Honda due to the exhaust running under the engine.
    I haven't used it yet, but figure I will when I clean and adjust the chain.
    Dumb question: should I remove the skid plate before sliding the lift under or is the skid plate sturdy enough to leave on?
    Ken likes this.
    Junior Member Bronxborn's Avatar
    Oct 2016
    6
    Quote Originally Posted by revtbob View Post
    I currently use this lift
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I lift from the swingarm pivot section, just avoiding the skid plate. I personally would remove the skid plate since it feels rather flimsy if you choose to lift from the case.
    revtbob and Fred like this.
    Pleasanton, CA
    4,224
    That's a good question, here is what I do. Since the stock skid plate is made from old dog food cans and is pretty flimsy, I place a rectangular piece of plywood across the arms of the lift so that the weight of the bike is more evenly distributed and not focused on just two points. I would also recommend attaching a couple of straps to tie the handlebars to the lift because it will be pretty unstable without them.
    site:tw200forum.com
    Nov 2010
    1,998
    I prefer to hang it from above using block and tackle or comalong. Imobilize the front wheel in a brace or between two objects.
    It will never fall over no matter how hard you lean on the wrenches.
    Smitty Blackstone likes this.
    Phelonius
    Senior Member drstimpy's Avatar
    Oct 2013
    Rochester, MA
    172
    Pictures 🤡
    Some must watch while others must sleep.
    2013 TW 200
    2014 NC700x
    2016 k1600gt
    2016 TW 200
  1. Floor Jack
    By youngfred in forum General Discussion
    Last Post: 03-07-2017, 09:18 PM
  2. Center bike lift/tranny lift?
    By Hidebound in forum Off-Topic
    Last Post: 07-07-2015, 08:51 AM
  3. Replies: 6
    Last Post: 04-18-2015, 09:23 AM
  4. Trail Jack
    By r80rt in forum Technical Help
    Last Post: 07-21-2013, 10:37 PM
  5. Stand or Jack?
    By nfpgasmask in forum Technical Help
    Last Post: 09-25-2012, 09:52 PM
