Make a $10 Valve Spring Compressor
Results 1 to 7 of 7
Like Tree34Likes
  • 14 Post By TW-Brian
  • 7 Post By Fred
  • 5 Post By old w/2 many guns & bikes
  • 3 Post By Tweaker
  • 2 Post By admiral
  • 2 Post By Fred
  • 1 Post By elime
Thread: Make a $10 Valve Spring Compressor
    Pleasanton, CA
    4,224
    Here is a universal type valve spring compressor that I have used for a number of years. While it is functional, it is kind of clumsy and difficult to get adjusted and positioned (just ask Fred!).
    When I saw that Admiral had made one from an old C-clamp, I just had to make one myself. In this thread you can see Admiral's and also my initial unsuccessful attempt at using a Harbor Freight clamp.
    Head & Cylinder Repair Notes
    Here is Admiral's.
    I was able to find a 4" Husky brand C-clamp at Home Depot with a 3" deep throat that looked like it would work. Using a bench grinder, angle grinder, various hand files and a wire wheel I re-shaped the fixed end of the clamp as shown below. I did not have as much material to work with as Admiral's clamp, so mine turned out a little daintier than his.
    Here it is positioned on a TW head.
    Here is a close-up of it in position. Not a lot of extra room, but enough.
    (p.s. thanks to Admiral for the inspiration and luckily, no hammers were harmed in this project)
    site:tw200forum.com
    In The Sierras Test Riding New Fuel Additives for my Tortoise Wanderer
    12,251
    What would we ever do without TW-Brian and Admiral? That's some good clamping action! clip.mp4
    Lights, Action, Traction....Let's Ride!
    2003 model year, jetted for mile high+ riding, Wiseco 68mm piston, Duro ATV rear tire, IRC GP-1 Trials front tire, XT-225 tank, Cyclerack, 2" handlebar risers, foot pegs, D-flex hand guards, right angle fuel filter, Seat Concepts kit over additional hi-density foam, fluorescent paint, Betty Boop stickers..and a lot of scratches!.
    Senior Member old w/2 many guns & bikes's Avatar
    Apr 2014
    422
    The Clampits - Which one is Jed and which one is Jethro!
    Dec 2015
    San Diego
    809
    This is a cool thread thanks.
    TW-Brian, admiral and littletommy like this.
    Twin 2014 TW200's made side by side on the assembly line, Moose rear racks, Protaper Bars one with risers, DG oval pipes. rejetted carbs, 130 main jets, 2 -.020 shims on the needles and @ 2 1/2 turns on the pilot screw, #34 pilot jets, Aserbis hand guards, Shinko 241 front tires, weld on foot pegs, 14-55t sprockets, Ricochet skid plates and 90 degree fuel filters.
    Sand Hollow, ID
    9,281
    Yours looks really good Brian. Mine looks like a real hack job with the grinder marks and rust on the c-clamp visible. Nicely done!
    littletommy and TW-Brian like this.
    12,251
    Admiral, rusty or not you did pioneer a superior design.
    When TW-Brian loaned me his spring compressor I probably paid more in the return shipping fees than the cost of a donor C-clamp. Then I likely spent just as much time adjusting Brian's compressor as I would have spent grinding the C-clamp. MissingLinkMasterA.jpg
    TW-Brian and admiral like this.
    5,775
    The C-clamp versions are better, cheaper, easier to use than the POS dedicated tool I wasted my money on! Next time I go to HF I will be also getting a C-clamp. Tony
    admiral likes this.
  1. Compressor saver.
    By Reddog in forum Off-Topic
    Last Post: 06-07-2016, 10:44 PM
  2. Mini Air Compressor
    By sponge in forum General Discussion
    Last Post: 10-04-2015, 10:47 PM
  3. Coil Spring Compressor From Mostly Scrap
    By Hekkler in forum Performance and Customization
    Last Post: 01-27-2015, 04:15 PM
  4. Replies: 2
    Last Post: 06-06-2014, 08:18 PM
  5. Tw make over bobber style please help me make this happen
    By Sahjj in forum Performance and Customization
    Last Post: 10-04-2013, 07:18 PM
