Modification Of OEM Rack - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Like Tree28Likes
Thread: Modification Of OEM Rack
  1. #11
    Spokane, Washington
    13,812
    Aba-2jy51-00-00
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
  2. #12
    Senior Member Gulfrider's Avatar
    May 2014
    South Florida
    360
    Actually funny you posted this as I'm getting ready to do just this to my oem rack. its weak we know that. I plan on adding braces/tubing to areas like the man rack show, and beefing up the under seat area. And plan to flatten as you said. I just bought a mig welder so having fun playing and this will be another fun project.
    2005 TW200
    2007 Sportster 1200
  3. #13
    Sand Hollow, ID
    9,281
    Quote Originally Posted by GCFishguy View Post
    Just kind of looking for opinions
    For reference, a piece of two-by is the right thickness to plunk on the rack, and be pretty much level with the upturn. I'd rather not use 2x4's....
    Instead of wood 2x4, maybe you could use aluminum square tubing or something similar. Cut some small blocks to attach case>tube>rack.
    My modus operandi (M.O) would be to try and use a torch to soften the metal and bend it like you are thinking. Perhaps I would use a hammer to help bend the metal but I would only suggest this by placing something like your 2x4 on the metal and then strike the 2x4 with the hammer thus not roughing up the metal with the hammer.
    Good luck.
    Smitty Blackstone likes this.
  5. #14
    Sep 2014
    Mamaroneck, NY
    1,768
    Do you need one?
    Quote Originally Posted by Deepseadan View Post
    You wouldn't happen to know the part number would you?
    littletommy likes this.
  6. #15
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    460
    With all the great inventors, modifiers, tinkerers, welders on here I am surprised no one has unbolted that back section under the seat to the back of the bike and just strengthened that and the frame it hooks to. It looks like this would be simple and wouldn't add much weight. A smaller lighter rack could bolt to it possibly with very good strength. I know most love the cycle rack but it looks huge and heavy.
  7. #16
    Senior Member Deepseadan's Avatar
    Sep 2016
    So Cal
    215
    Quote Originally Posted by Smitty Blackstone View Post
    Do you need one?
    Yeah I was thinking on getting one so I could carry my msr fuel bottle on the rack instead of my backpack. It looks small and simple. But when I saw the amazon prime prime price of $125 I changed my mind. More than I can spend right now.
    Current bikes 2016 KTM 500 EXC, 2016 Yamaha TW 200
  8. #17
    Sep 2014
    Mamaroneck, NY
    1,768
    Check your PMs.
  9. #18
    Senior Member LuvNot's Avatar
    May 2015
    Hampton, VA
    612
    If you need to fill space to make a flat spot, I recommend 2 cutting boards (one 1/4" thick or more and the other just sheet plastic) and some closed-cell foam (boards of the solid pink or blue stuff used to insulate houses).
    Before you sneer at using the foam, I assure you it is much stronger than you might think. Shape it to fit the curve of the OEM rack, place the thin cutting board between the foam and your box, and put the thicker board under the rack. Drill holes where needed and bolt it all together. Because you will be compressing the foam between two solid surfaces, there will be little to no friction. Your Pelican box will be held tight. So for very little money and very little weight gain, you'll have a nice flat surface to attach the perfect cargo box.
    My 2-Wheel Babies: 2006 Kawasaki Nomad 1600 - 2009 Piaggio MP3 500 - 2011 Genuine Scooter Co Blur 220i - 1999 Yamaha TW200
  1. Rear Rack Yamaha OEM TW200 Rack
    By PlacerLode in forum TW200 Classifieds
    Last Post: 03-31-2016, 09:41 PM
  2. OEM Rack
    By Rhodetrip in forum TW200 Classifieds
    Last Post: 02-28-2014, 10:07 PM
  3. OEM rear rack
    By Kcfranqui in forum TW200 Classifieds
    Last Post: 11-30-2013, 07:58 AM
  4. OEM Tail Rack for sale
    By 50short in forum TW200 Classifieds
    Last Post: 11-07-2013, 12:41 PM
  5. OEM TW Rear Rack - SOLD
    By Larry in forum TW200 Classifieds
    Last Post: 03-13-2012, 06:01 PM
