Carburetor Adjustment help - Page 2
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 78
Like Tree153Likes
Thread: Carburetor Adjustment help
  1. #11
    Member stevericotta's Avatar
    Apr 2017
    Burbank, Ca
    30
    I'm back with another question/confirmation. So did the o-ring and boot and it's a lot better. The only issue I have and I think its me is when I hit the throttle hard (no load on the bike) to rev it up is falls flat for a second. I think its me because I am used to a bigger bike.
    Also I am about 6 turns out on the mixture screw. I live in Burbank Ca which is about 700' above sea level. Does that sound right to you guys? Here is a picture of the plug. What do you guys think?TWplug 2.JPG
  2. #12
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,205
    6 turns out is too much. I'm surprised the screw hasn't fallen out.
    Somethine is still wrong.
    jb
    littletommy and cowboyjeff like this.
    2017 Triumph Bonneville T-120.......2015 CSC Zong
  3. #13
    Apr 2017
    Burbank, Ca
    30
    I hate to say it but that's what I think. Any ideas? I sprayed around the boot again to make sure there wasn't another leak and it was fine. Carb has been rebuilt will all start brand new parts. Any help would be great.
    Thanks!
    cowboyjeff likes this.
  5. #14
    Spokane, Washington
    14,134
    And if you dial it to 2 1/2, what happens?
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
  6. #15
    Apr 2017
    Burbank, Ca
    30
    It wont run unless I have the choke open.
    One thing I did notice is on the right side (sitting on the bike) there is a black plug that turns but does move (it takes a flat head screw driver). Looks like the guy I got if from chewed it up. Not sure what that is. Anyone?
  7. #16
    Apr 2017
    Burbank, Ca
    30
    Okay so I just popped out that black mangled piece of plastic and it was for the guild for the carb ""piston" so it doesn't turn when opening the throttle. Could that do it? Is air getting that little slide or is maybe the piston turning ever so slightly when I twist the throttle?
  8. #17
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    6,018
    We have heard this more than once. That black plug is the piston slide guide that goes through the barrel and should "NEVER" be messed with. I don't know if it can be replaced and I also don't know if this could be causing your issue. The slide must remain aligned inside the barrel so without the guide pin all bets are completely off. You mention the pilot screw is now at 6 turns out. Lets be sure you are counting correctly. The screw has a straight slot so one turn should be two complete revolutions of the slot with each revolution being a half turn. If you are counting just half turns then 5 half turns is where you should start. On a clock face if you turn it from the 3 to the 9 that is a half turn, turn it again around to the 3 and that is one full turn out. Most TWs run pretty good at between 2 1/2 -3 complete turns. In my opinion your spark plug color looks a bit lean to me.
    2006 TW200
    2006 XT225
    1974 Boston Whaler Montauk
    1989 Lowe Lunker
  9. #18
    Apr 2017
    Burbank, Ca
    30
    Thanks for the feedback. It looks like from all the research I did last night that plug cannot be replaced. I will try and find a carb on eBay and go from there. Also thanks for the clarification on the turns. Looks like I have been doing it right.
    Thanks!
    Steve
  10. #19
    5,855
    What size pilot get are you using? If the needle is 6 turns out then I bet you need a larger pilot jet.
  11. #20
    Apr 2017
    Burbank, Ca
    30
    I can look when I get home but its what comes with the rebuild kit. Also I found a carb for a 1991 on ebay buts its not a california model. Will that work for my bike?
    Thanks!
    Steve
  1. Carburetor ?'s...
    By dwil4 in forum Technical Help
    Last Post: 01-22-2017, 01:38 PM
  2. Which carburetor to get?
    By RobG in forum Technical Help
    Last Post: 04-20-2015, 06:15 AM
  3. Carburetor
    By emilliano in forum Technical Help
    Last Post: 10-05-2014, 01:32 AM
  4. Carburetor Wanted for my TW
    By Motorbike1956 in forum TW200 Classifieds
    Last Post: 07-26-2014, 05:09 PM
  5. Carburetor help or different carburetor options
    By dz1 in forum Technical Help
    Last Post: 05-21-2011, 08:24 PM
