Carburetor Adjustment help
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 80
Like Tree161Likes
Thread: Carburetor Adjustment help
    Member stevericotta's Avatar
    Apr 2017
    Burbank, Ca
    31
    Good evening everyone! I'm a newbie from Burbank Ca, and I could use some help. I just bought a 1990 TW200 that was sitting for a while so I rebuilt the card, changed the oil, etc. It's in great shape but after rebuilding the Carburetor I am having some issues. So here is the skinny. I bought a carb rebuilt kit from Yamaha, as well as the diaphragm. I put the carb back on the bike, set the mixture screw 2.5 turns out (base setting I think) and started the bike with the choke on. No problem started right up but as soon as I take the choke off it dies. So long story short I have to have the mixture screw out about 5.5 turns for it to start up and idle without the choke. However once I give it gas it falls on it face. It wont die and if I feather it, it will rev up. So I spent about 2 hours trying every mixture setting and I can get it to close but there is always a flat spot and its running really lean. The plug is white.
    Sorry if this is long but I wanted to explain it best I could. I have read a lot of the posts about adding shims and jets but for now all I am trying to do is get it back to stock.
    Thanks for the help!
    littletommy likes this.
    Jan 2017
    Southern Nevada
    245
    Check for a vacuum leak
    Apr 2017
    Burbank, Ca
    31
    Would you know where I could look? I replaced the gas line and other than the vent tube for the canister there is nothing else.
    6,023
    Could be a clogged, or partially clogged pilot jet or a leaky o-ring on the idle mixture screw.
    Member MidnightRider's Avatar
    Oct 2015
    Orange County, CA
    39
    It's a 90. The carb boot could be shrunk, leaking air, or have a crack somewhere.
    littletommy, GaryL and cowboyjeff like this.
    Spokane, Washington
    14,492
    Welcome to the forum!!
    Quote Originally Posted by stevericotta View Post
    Ken likes this.
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    6,219
    The very first place to look is in the boot between the carb and air box. If that is not a ful seal then forget about getting the carb adjusted. While it is running at idle spray some WD or carb cleaner around the boot and if the rpms go up or down you have a leak. Also check to be sure the mice have no nests in the air box behind the battery where it sucks air from. Some guys like to stuff a rag down in that section for wiping their hands not realizing this is the air intake.
    2006 TW200
    2006 XT225
    1974 Boston Whaler Montauk
    1989 Lowe Lunker
    Apr 2017
    Burbank, Ca
    31
    Laying in bed last night I thought the same thing! check the Manifold/boot.Great info all, thanks for the help. I will give is a look after I get back from church and send an update.
    Thanks!
    littletommy and cowboyjeff like this.
    Apr 2017
    Burbank, Ca
    31
    Looks like it is the o-ring between the boot/manifold. Ordered both just to be safe so I should be riding by the end of the week.
    Thanks for all the feedback!
    Steve
    Jun 2013
    Forestburgh, NY
    6,219
    Good idea Steve. The Boot connection between the carb and the air box is famous for shrinking and becoming very hard so you can't get a good seal. The boot between the carb and the engine is know to crack and become very brittle from the heat. If either boot is leaking then it essentially throws your Air-Fuel mixture completely off so adjusting the Pilot screw is pretty much meaningless.
    2006 TW200
    2006 XT225
    1989 Lowe Lunker
  1. Carburetor ?'s...
    By dwil4 in forum Technical Help
    Last Post: 01-22-2017, 01:38 PM
  2. Which carburetor to get?
    By RobG in forum Technical Help
    Last Post: 04-20-2015, 06:15 AM
  3. Carburetor
    By emilliano in forum Technical Help
    Last Post: 10-05-2014, 01:32 AM
  4. Carburetor Wanted for my TW
    By Motorbike1956 in forum TW200 Classifieds
    Last Post: 07-26-2014, 05:09 PM
  5. Carburetor help or different carburetor options
    By dz1 in forum Technical Help
    Last Post: 05-21-2011, 08:24 PM
