FMF exhaust - now what?
Results 1 to 10 of 10
Like Tree17Likes
  • 1 Post By Dennis
  • 2 Post By grewen
  • 2 Post By Purple
  • 2 Post By jb882
  • 1 Post By Purple
  • 2 Post By elime
  • 3 Post By Deepseadan
  • 1 Post By JerseyJeeper
Thread: FMF exhaust - now what?
    Junior Member Dennis's Avatar
    Mar 2017
    4
    Hi guys, I just bought a TW that has an FMF exhaust. The spark plug is white. What do I need to do to make this exhaust work on my bike?
    Thanks in advance
    Ken likes this.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC.. 1957 km from moab
    1,394
    if you like the muffler, and are going to keep it, then some carb tuning is in order. richen it up a bit. go to the technical section and read some of the write ups on the subject. if you're going to put the stock muffler back on, or modify the FMF, do that first and then fool around with jetting and welcome to the forum
    JerseyJeeper and Ken like this.
    2014 tw
    2016 bolt
    1981 honda ct110
    1973 honda ct90
    Mar 2015
    Ynys Môn
    2,332
    Sounds like you need a bigger main jet
    Not a carb man myself, so I'll hand you over to the rest of the pack
    Welcome to the board ....
    TW200 - 1998 - Japanese import - 5000 miles on the clock - TW225 Special Edition 2007
    Senior Member jb882's Avatar
    Aug 2013
    1,154
    You need a bigger main jet. I would get each of the bigger sizes than what you have and test until it it right.
    Ken and JerseyJeeper like this.
    Mar 2015
    Ynys Môn
    2,332
    JerseyJeeper likes this.
    5,862
    What year TW? How many miles on the plug?
    Find out what jet you have in the carburetor now and then order some richer and maybe one or two leaner.
    https://www.aliexpress.com/item/12-m...608.0.0.SSGwjq
    Ditto for the pilot jet.
    https://www.aliexpress.com/item/12-p...608.0.0.SSGwjq
    I have used these main jets with satisfaction but the verdict on the pilot jets is still out. Hopefully one will soon be tested by a forum member in Burbank. As far as I know I am the only forum member that uses AliExpress main jets.
    Senior Member Deepseadan's Avatar
    Sep 2016
    So Cal
    251
    I'd call fmf customer service and tell them your bike make and model and what exhaust you purchased and will tell you how to jet your carb. They should know better than any of us.
    Sent from my iPhone using Tapatalk Pro
    littletommy, elime and Ken like this.
    Current bikes 2016 KTM 500 EXC, 2016 Yamaha TW 200
    Senior Member JerseyJeeper's Avatar
    Mar 2011
    NJ Shore / Pine Barrens
    2,247
    Quote Originally Posted by Deepseadan View Post
    Ken likes this.
    Sep 2016
    So Cal
    251
    Quote Originally Posted by JerseyJeeper View Post
    Ok read it to fast, not what fmf pipe you purchased but what exhaust is on your bike. When I purchased a fmf exhaust for my old quad I played around with jetting and never got it quite right. Called fmf and they told me what jets to install and the quad ran perfect after that.
    JerseyJeeper, Ken and Purple like this.
    Mar 2017
    4
    Thanks for the responses. I figured it out: The jet was very loose. So fortunately an easy fix.
  1. Want to Save $100 on an FMF Exhaust System for your TW?
    By TW-Brian in forum TW200 Classifieds
    Last Post: 09-20-2013, 10:10 PM
  2. Reverting to stock exhaust from FMF/spark arrestor
    By bruisr in forum General Discussion
    Last Post: 10-22-2012, 11:18 PM
  3. After Market Exhaust DG & FMF
    By doctorforgolf in forum Technical Help
    Last Post: 11-03-2011, 06:53 PM
  4. FMF Exhaust First Impressions
    By abyssdncr in forum Performance and Customization
    Last Post: 10-17-2010, 02:48 PM
  5. FMF exhaust on eBay
    By in forum General Discussion
    Last Post: 12-31-1969, 07:00 PM
