Start up *Help in Sacramento :(
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Like Tree110Likes
Thread: Start up *Help in Sacramento :(
    Member Ldw777frog's Avatar
    Mar 2017
    Orangevale, CA (near Sacto)
    38
    Hi all-
    Bought my first TW at the end of March '17. A garaged '94 with <2000 Miles that started right up and drove perfectly. Came with a battery tender and maintained regularly.
    Because of it's age, I took it in for new tires... and now it will not start at all. I haven't been able to ride it since I picked it up from the local yamaha dealership.
    I tried to troubleshoot it myself since I picked it up..
    new gas
    New ignition coil
    new air filter
    new spark plug
    took apart carb and it is in like new condition. no plugs or leaks.
    Cold compression app. 114 psi (since I can't get it started).
    Checked all the safety shut offs (kickstand, neutral, etc). Won't start in neutral with kickstand up or down.
    Did the TW tilt to the left and that didn't help either.
    Q: How do I know if the spark is good enough? I see a faint spark when I test it... but is it enough?
    I hate to replace the expensive CDI unless I am sure if that's the problem.
    I'm at a loss and super frustrated. I want to ride my bike!
    Any ideas or local help would be greatly appreciated!
    Thanks~ Laura
    littletommy likes this.
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    631
    Thanks for stopping by Laura Hope you get it running soon
    05-BMW1200GS- Rock Red 102k miles
    2013-TW200 - 5k- miles
    Member CJ7Pilot's Avatar
    Mar 2017
    Yuba City, CA
    32
    Did you ask the dealership about it? Presumably you did, and they weren't too helpful, which led you to do your own troubleshooting (which was a good idea).
    Are you engaging the choke when you try to start it?
    It sounds like you've got the fuel system pretty clean, so if the petcock is "on," and there's fuel in the carb, and the airway is clear, I'd be looking at the spark.
    You're seeing a spark (however faint), which means your engine is cranking over... is it cranking with "gusto," or is it just barely turning? What happens when you try the kick-starter?
    I'm new to TWs myself, but I think I read somewhere that the ignition systems on '88s and up are pretty dependent on good battery voltage (mine is an '87, and the wiring is quite a bit different).
    When you turn your key on, your headlight puts an immediate draw on the battery, and then the starter draws even more... maybe it's not making enough voltage to run the bike...?
    Maybe try charging the battery (with a real charger, not just a battery tender), then try starting the bike with the charger still attached.
    Maybe also get in to the wiring, and unplug/replug every connector to ensure good electrical connections.
    These bugs can be very frustrating to chase down.
    Good luck!
    6,023
    Pour a little gas into the spark plug hole and I bet it fires right up. If it keeps running you are done. If it dies you have a fuel problem but my guess is there is nothing wrong and it will keep running.
    Choke on, throttle closed, then crank it.
    And welcome -- a new member for the NorCal Nutjobs! Tony
    Correction: I looked up the official name and it is a very unimaginative "Northern California T-Dubbers".
    Nov 2011
    norcal nutjob
    2,845
    another rainbow warrior! welcome, and best of luck getting it started. i'd be buzzing at the shop that took it in running and returned it not.....
    littletommy and cowboyjeff like this.
    Senior Member Rockit's Avatar
    Jun 2016
    Sacramento
    111
    Omega Motorcycle (not a dealer) in West Sacramento is excellent and they work on T-dubs. Ask for Tony. Excellent customer service in my multiple dealings with this shop.
    Senior Member Deepseadan's Avatar
    Sep 2016
    So Cal
    281
    This sounds crazy and to simple but try giving it a tiny bit of throttle as your crank the starter. This is how I have to start my tw every once in a while when it's stubborn.
    Sent from my iPhone using Tapatalk Pro
    Current bikes 2016 KTM 500 EXC, 2016 Yamaha TW 200
    Spokane, Washington
    14,492
    Welcome!! Hope you find out what it is soon and are able to ride!! Keep us posted on what it was...
    cowboyjeff likes this.
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
    Mar 2015
    Ynys Môn
    2,433
    Kill switch
    TW200 - 1998 - Japanese import - 5000 miles on the clock - TW225 Special Edition 2007
    6,023
    The spark is hard to see especially in bright light.
    Pour a little gas in the spark plug hole.
    Spark + gas + compression = a running engine, if only briefly, but it tells you the spark and compression are good and your problem is in fuel delivery.
  1. 02 TW200 for $2200 in Sacramento sold
    By evan in forum TW200 Classifieds
    Last Post: 02-06-2013, 10:43 PM
  2. 91 TW200 near sacramento $300
    Last Post: 07-06-2012, 09:17 AM
  3. 08 tw on Sacramento Craigslist
    By evan in forum General Discussion
    Last Post: 04-26-2012, 10:59 AM
  4. Sportsman show at cal expo (sacramento, CA)
    Last Post: 01-17-2012, 10:47 AM
  5. Newbie Sacramento
    By Danny in forum General Discussion
    Last Post: 08-08-2010, 11:56 PM
