Running/ choke issues?
Results 1 to 8 of 8
Like Tree19Likes
  • 1 Post By Waymore
  • 3 Post By scotti158
  • 3 Post By elime
  • 3 Post By Tweaker
  • 3 Post By supachip1
  • 1 Post By jbfla
  • 5 Post By Waymore
Thread: Running/ choke issues?
    Junior Member Waymore's Avatar
    Apr 2017
    Payson, Utah
    18
    I just bought a 92 tw and it will not run unless it's at least half choked. It will hold itself revved up at time when I'm not touching the throttle then other times it will just die if I let it idle down when I'm stopping or something. I know it say with ethanol fuel all winter long. Could the carb just need cleaning? Or could it be something else?
    littletommy likes this.
    May 2013
    Groton, NY
    1,939
    Plugged pilot jet. A good carb cleaning is needed. Just replace the pilot jet while your at it.
    cowboyjeff, Purple and littletommy like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    5,862
    Try easy first -- open the idle mixture screw 2.5 to 3 turns.
    littletommy, Purple and cowboyjeff like this.
    Dec 2015
    San Diego
    916
    And try some seafoam too it may clear up.
    littletommy, cowboyjeff and Purple like this.
    Twin 2014 TW200's made side by side on the assembly line, Moose rear racks, Protaper Bars one with risers, DG oval pipes. rejetted carbs, 130 main jets, 2 -.020 shims on the needles and @ 2 1/2 turns on the pilot screw, #34 pilot jets, Aserbis hand guards, Shinko 241 front tires, weld on foot pegs, 14-55t sprockets, Ricochet skid plates and 90 degree fuel filters.
    Apr 2013
    290
    just had the exact same thing, clogged pilot jet, i soaked mine in diesel overnight and used a pin and compressed air, all sorted now
    Purple, littletommy and cowboyjeff like this.
    Member cowboyjeff's Avatar
    Nov 2013
    West Jordan, Utah
    62
    Im with the others, Dirty Pilot Jet & or Pilot circuit. Like Elime said well you have the Carb off pop the Cap off the Idle air adjusting screw and start at 2.50 turns out. Also you probably ought to make sure there is no rust in the tank.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,207
    Quote Originally Posted by Waymore View Post
    ........ I know it say with ethanol fuel all winter long......
    Fresh gas would help, too.
    jb
    cowboyjeff likes this.
    2017 Triumph Bonneville T-120.......2015 CSC Zong
    Apr 2017
    Payson, Utah
    18
    Thanks for all the replies guys! I took the carb apart today and man was it filthy. Replaced all the jets and o rings and stuff and cleaned the rest up so hopefully it does the tricks. But first I have to replace the boots on each side between the engine and the air filter box.
  1. Replies: 48
    Last Post: 06-28-2016, 08:44 PM
  2. Engine stops running when choke is pushed in.
    By PJinNJ in forum Technical Help
    Last Post: 06-20-2016, 08:10 PM
  3. Running issues.
    By cmercon in forum Technical Help
    Last Post: 08-28-2015, 11:12 PM
  4. 93 TW Starting and Running Issues
    By Squatch Buster in forum General Discussion
    Last Post: 08-05-2015, 08:31 AM
  5. Carb / Choke issues
    By ebikerman in forum Technical Help
    Last Post: 02-10-2013, 09:09 PM
