Cylinder Head Question - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
Like Tree44Likes
Thread: Cylinder Head Question
  1. #11
    5,932
    If it were me I would use that cylinder. Hone it for sure, ball hone or cylinder hone, just enough to clean up most of the surface. Also, if going with the 67mm Wiseco, the piston to cylinder wall clearance should be .0025 inch. If it were mine I would make it .003".
    Your piston looks like it overheated and expanded and scraped the cylinder wall. Aluminum from the piston sticks to the cylinder wall and looks terrible! Reality is you can clean it off and the cylinder is in good shape. Steel is much stronger than aluminum and the steel usually wins. BTW, increasing the clearance to .003" is to allow for more expansion.
    Be careful changing plans. Most of the time that only leads to delays and more money being spent. Good luck. Tony
    DrTerrible, cowboyjeff and Ken like this.
  2. #12
    5,932
    Quote Originally Posted by DrTerrible View Post
    Attachment 99969
    And here is the scratched one
    That looks worlds better than the cylinder I showed. I think once you clean the aluminum up and hone it and and get the correct piston to cylinder clearance it will work fine.
    You can check the clearance using feeler gauges. Not real accurate but it works.
  3. #13
    Senior Member DrTerrible's Avatar
    Jun 2016
    Sherwood Park, AB
    214
    Thanks for your insight Tony, I really appreciate it. I will be picking up the cylinder tomorrow from my engine guy and dropping it off at a machine shop and see what they have to say. I will ask them to go to .003 as I trust your expertise. You are right about the delays and more money being spent. I am crossing my fingers that the cylinder is okay and my piston comes in PDQ. The piston and front/rear blinkers are all I need to take her on her maiden voyage, after the sanding and painting of the frame and plastics. It has been almost a year getting parts/dealing with setbacks, being a new father and a lot of doubts about rebuilding this bike...but I can't wait to get this thing on the road and start with the next journey of a tw/ttr conversion. Everyone on this forum has helped out a great deal and it is greatly appreciated. Sorry for getting sappy, it's late, I'm rocking my baby boy to sleep and thinking I can't wait until he is old enough to help me work on the bikes. Who knows, maybe one of these tw's will be his one day as his first bike.
  5. #14
    Member neckless's Avatar
    Dec 2015
    dryden ont canada
    89
    for the six diff engines i had honed i drop of cyc and they measure and supply piston of your choice and they fit that piston to that jug..... usually for a very good price....this is a engine repair shop.....
    Ken likes this.
  6. #15
    Jun 2016
    Sherwood Park, AB
    214
    Apparently I am supposed to wait until the piston comes then he will check the clearance but he said best option would be to bore it to the next size up. Wish I would have done more research instead of just pulling the trigger and buying the stock piston.
  7. #16
    5,932
    I detect a lot of regret here. Maybe you would be better off returning the piston for a larger one. It will be time and money well spent.
    I may not have gotten the clearance thing quite right -- make it .0005" larger than the minimum. If the minimum is .002, then make it .0025. If the minimum is .0025, then make it .003. It should say on the outside of the box what the minimum clearance is. It has been a while since I honed a cylinder for a larger piston.
    Ken likes this.
  8. #17
    Jun 2016
    Sherwood Park, AB
    214
    I think that is what I will have to do. I havent received the piston in the mail yet so i cannot look at the box for the clearances. I think i will return it and have to wait another 3 weeks to put the motor together.
    " Waiting is the hardest part."
    Tom Petty
    Ken likes this.
  9. #18
    Jun 2016
    Sherwood Park, AB
    214
    Got my piston and the clearance is 0.0020. Can anyone tell me the maximum they can bore until for the piston to work?
    Ken likes this.
  10. #19
    5,932
    .0020 in the minimum clearance. I bet you could go .004 or even .005 and it would still work OK though I bet you machinist will be against it.
    The question is what is the diameter of the piston measured at the bottom of the skirt minus the diameter of the cylinder? That is the clearance.
    You can get a rough idea with feeler gauges but it scratches the piston -- the scratches are harmless but I bet it won't be accepted as a return if it is scratched.
    The place to measure the diameter as told to me by Wiseco:
    One can then put the piston in the cylinder and measure the clearance with a feeler gauge. It is not very accurate but you can get a ball park idea where you stand.
    A couple of things to keep in mind. The feeler gauge is flat and the cylinder/piston is round so there will be resistance from that. You don't want to strong arm the feeler gauge into place -- it should simply take up the excess space. In the picture it isn't being measured at the widest point so the measurement will be a little bit large -- it is actually about .0028 and if I pushed the piston in with the feeler gauge where it is the feeler gauge would be wedged tight in place -- which is no good.
    Best bet is take it all you your machinist and let him measure it with micrometers then make you decision what to do.
    And another picture just for the heck of it. This one and the ones above are a 71mm Wiseco piston in a 223cc cylinder. I thought it looked pretty so I posted it.
  11. #20
    Senior Member JerseyJeeper's Avatar
    Mar 2011
    NJ Shore / Pine Barrens
    2,271
    Nice post Tony!
    elime and Ken like this.
    XT225 - 1999 Serow... (Now in the Coral!) Yay
    TW200Z - 2010
    BW200 - 1986
    TTR225R - 2003
    Husqvarna 701 - 2017
  1. Cylinder and Head changes and interchangeability
    By stranger in forum Technical Help
    Last Post: 02-11-2015, 09:24 PM
  2. Cylinder Head Compatibility
    By toby in forum Technical Help
    Last Post: 05-04-2014, 04:24 AM
  3. WTB cylinder head
    By vanillagorilla1 in forum TW200 Classifieds
    Last Post: 11-05-2013, 10:28 PM
  4. cylinder head
    By ldw72120 in forum Technical Help
    Last Post: 11-03-2011, 08:09 AM
  5. cylinder head
    By christddel in forum Technical Help
    Last Post: 02-28-2011, 04:38 PM
