Broken Drain Plug - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Like Tree84Likes
Thread: Broken Drain Plug
  1. #21
    Senior Member AGman's Avatar
    Nov 2013
    Melbourne, Australia
    637
    Someone put the screen in backwards and it got crushed. It wasn't me. The bike came that way.
    I wouldn't of thought anyone could stuff that up...but here we are...
    Ken likes this.
    Resident Hidden Content specialist. Hidden Content
  2. #22
    5,932
    but I do want to see what you come up with to salvage that busted plug.
    You asked..............
    I would only use this plug is I was desperate! Very desperate!!! But it might work.
    Pictures are self-explanatory.
    admiral, Tweaker, TW-Brian and 2 others like this.
  3. #23
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    636
    That's a nice rig job.
  5. #24
    5,932
    I have virtually guaranteed, as much as humanly possible, that I will never need another oil drain plug again. I bought a spare.
    Ken, Tweaker, Dryden-Tdub and 2 others like this.
  6. #25
    Pleasanton, CA
    4,331
    Good to know, in case I ever need one!
    elime, Purple and Dryden-Tdub like this.
    site:tw200forum.com
  7. #26
    Nov 2010
    2,146
    I used to have a double square socket that I made so that I could check the torque reading on my click wrench against my beam type torque wrench.
    But on the subject of the thread, I hate it when the manufacturer makes a plug with aluminum threads to be used in a hole with aluminum threads.
    Honda used to do that on their rocker covers too. I have seen a lot of those cross threaded or stripped.
    Ken and elime like this.
    Phelonius
  8. #27
    Sand Hollow, ID
    9,526
    Couple dabs of epoxy here and there and you can have another spare. Of course the shade tree spare may be at the expense of a 1/4" tap!
    elime and Fred like this.
  9. #28
    Dec 2015
    San Diego
    1,049
    You are probably right Pelonius about using aluminum and thats why they use zinc. Maybe a little lead in the alloy or now with good plastics it could be glass filled nylon.
    Twin 2014 TW200's made side by side on the assembly line, Moose rear racks, Protaper Bars one with risers, DG oval pipes. rejetted carbs, 130 main jets, 2 -.020 shims on the needles and @ 2 1/2 turns on the pilot screw, #34 pilot jets, Aserbis hand guards, Shinko 241 front tires, weld on foot pegs, 14-55t sprockets, Ricochet skid plates and 90 degree fuel filters.
  10. #29
    5,932
    I cleaned up the flat sides a little so I can grab it with a crescent wrench -- if the plug isn't to tight it should work. Still looks crappy.
    I found a pin hole in the bottom of the hole I drilled. Since I was JB Welding the plug in the center in place I put a little in the hole and pushed down and it came out the other side. I am not sure it was necessary because maybe the o-ring would have covered it.
    admiral likes this.
  1. drain plug screw up
    By grewen in forum Technical Help
    Last Post: 05-06-2016, 07:32 PM
  2. Drain plug stuck
    By georgeDubya in forum Technical Help
    Last Post: 02-04-2016, 06:23 PM
  3. What is this and why was it in the drain plug screen
    By muddymopar in forum Technical Help
    Last Post: 12-15-2015, 04:31 AM
  4. MAGNETIC DRAIN PLUG
    By 1nonly in forum General Discussion
    Last Post: 05-04-2012, 07:39 PM
  5. Drain plug rounded off
    By chipyting in forum Technical Help
    Last Post: 04-15-2012, 03:26 AM
