Battery story - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Like Tree40Likes
Thread: Battery story
  1. #11
    Junior Member plordly's Avatar
    May 2014
    Cape Breton Island
    16
    Not to be smart but why disconnect the sparkplug wire...whynot just use the killswitch?
    Sent from my LG-H812 using Tapatalk
  2. #12
    May 2014
    Cape Breton Island
    16
    Whynot just use the killswitch vrs sparkplug wire removal?
  3. #13
    Senior Member arrowsmith's Avatar
    Missouri
    618
    One can always do a load test at home to evaluate a questionable battery. With the battery charged to say 12.8 volts or so disconnect the spark plug lead and engage starter motor for 20 seconds or so while monitoring decaying voltage across your battery. Should voltage drop below 9.6 volts during draw test conventional wisdom says battery is inadequate.
    I figure it is inadequate when it fails to start the bike.
  5. #14
    Hailey, ID
    2,485
    Um, I really don't think you want to find that out while 10 miles out in the boonies!
    Rocky
    2010 TW200
    2014 BMW R1200GS LC
  6. #15
    Missouri
    618
    If I am by myself I just ride two tracks and will be able to start it. May take a while to push it up hill but will not need much roll to get it started. Even in the boonies around here you just wait and someone will be by. I have lots of time to wait,I am retired and do not have to be any place on schedule. If no cell service ,just walk to top of hill and call Wesley and then set in shade and wait until he gets off work.
  7. #16
    Hailey, ID
    2,485
    Ah, the life of Riley!
    Rocky
    2010 TW200
    2014 BMW R1200GS LC
  1. New battery and tw will not maintain a charged battery
    By Mr.wiggle in forum Technical Help
    Last Post: 06-27-2016, 08:06 AM
  2. Battery Tender (battery) Headache
    By Dmd3058 in forum Technical Help
    Last Post: 04-03-2016, 04:10 PM
  3. Battery life sucks...what battery are you using?
    By rastaman in forum Technical Help
    Last Post: 11-02-2015, 01:14 PM
  4. Replies: 3
    Last Post: 02-05-2015, 11:55 PM
  5. my story
    By YTWTX in forum General Discussion
    Last Post: 05-02-2012, 09:30 AM
