Checking a stator-What ohms setting? - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Like Tree15Likes
Thread: Checking a stator-What ohms setting?
  1. #11
    Jan 2015
    Fair Oaks, Calif
    302
    Guess I would be chasing a voltage problem first... Making sure that the running voltage is above 13.8.... If it's up above 14.8 when rev'd up to <>2500rpm then that is not a healthy voltage...
    Then I would go after a drain on the battery doing an amp reading.... If there is an intermittent low amp drain that will be tough. An intermittent big amp drain might blow the system fuse.
    I will not get into how to troubleshoot/isolate intermittent drains on the battery yet. Wait see what the voltage's are... Just me.
    Jim
    Tweaker likes this.
  2. #12
    Senior Member Tuber's Avatar
    Sep 2012
    VT
    602
    to measure really low resistance, you generally need to run some current thru the circuit to get an accurate reading. not something that would very easy to do at home. Some shops have a test machine for this purpose, like a place that rebuilds starters n whatnot
    2005 Tdub
  3. #13
    Member chuckgarrett's Avatar
    Mar 2017
    Meridian, CA
    41
    Correct me if I'm wrong here...an over charged battery (if wet cell) becomes empty due to 'cooking' the battery. And if it's killing the battery due to a parasitic drain or running the bike with no charging, the battery will still have water.
    jtstdub likes this.
  5. #14
    Spokane, Washington
    14,212
    I think your assessment is correct if you have correctly checked and added distilled water as needed throughout the year and then all of a sudden your battery is boiling dry.
    Quote Originally Posted by chuckgarrett View Post
    jtstdub, Purple and socalnative like this.
    LittleTommy Hidden Content
    --In Memory Of--
    Our Fallen Heroes
    TW2007
    Lizrdbrth
    TWisty
    RonInBoise
    *Reserved*
    Rest In Peace Brothers.
    John 3:16-17
  6. #15
    Jan 2015
    Fair Oaks, Calif
    302
    Quote Originally Posted by Tuber View Post
    Yep sometimes one needs to have some current going through the circuit... An analog volt meter helps but Current is the tell tale most of the time. Easy to do for someone with electronics basics. Sure do not want much current.
    Example... A 1.5 vdc battery and a 10 ohm resistor in series with a .6 ohm coil will produce 141 milliamps of current. That is not enough current to harm the coil. If the coil has a bad connection it might open or read less current that 141.
    If the coil has a couple of windings shorted, which does happen then the current will go up, one or two windings shorted is not going to produce much of a current difference. Problem is, at what point will the coil not produce enough of a pulse (amplitude) to render the CDI inoperative or create the god awful intermittent miss. I personally would want to scope it... BUT in the example of a couple of coils shorted that even may not work.... I do think scoping is the best avenue and the current test with resistance is second best.
    Automotive coils create the same kind of issues... Resistance =good but get it warm and the thing starts opening, usually in the primary.
    Jim
  7. #16
    Mar 2015
    Ynys Môn
    2,406
    Your assumption is correct
    If a battery is getting excess charge through the reg/rec unit - (which happens because although the reg/rec is supposed to dump to earth if it fails, occasionally it goes wide open and cooks the battery) — constant over-charging will boil the battery fluid off
    If the reg/rec has failed and gone to earth, then you can also (mildly)boil the battery through over use, but the effects will be much less
    If your stator was at fault — then the results will be much the same, but first the point of stress would have to be on the reg/rec unit
    The reg/rec unit has to fail before anything gets through (or not) to the battery ……..
    jtstdub likes this.
    TW200 - 1998 - Japanese import - 5000 miles on the clock - TW225 Special Edition 2007
  8. #17
    Mar 2017
    Meridian, CA
    41
    Quote Originally Posted by jtstdub View Post
    I run into this at work. A circuit will ohm check good but when a load is put on the circuit the voltage goes away. Sometimes even see 12v potential then 0v with load on. Too much corrosion or a bad connector involved. Just enough contact to get an ohm or volt reading not enough to carry a load.
    I use a tester that injects a high current for a milli amount of time. Disconnecting both ends of the wire as to not blow a circuit board or module, of course. A simple light bulb used for a load and a volt meter measuring the voltage drop works good.
    To find parasitic drains I hook an amp meter in series to the battery cable and start pulling fuses until the drain stops. Then wiggle wires and connectors in that circuit to find the drain.
    Tuber likes this.
  9. #18
    Mar 2017
    Meridian, CA
    41
    Oh, and my coil test is like my thermostat test. If a coil is suspect, I throw it up in the air and if it comes back down I replace it.
    I know that test may not work in this particular case...
  10. #19
    Sep 2012
    VT
    602
    Quote Originally Posted by Hidebound View Post
    Currently chasing an electrical gremlin - oh the joy. There are lots of threads on checking the phases of a stator with a volt meter but not a one of them I can find say exactly which notch on the meter I need to be using - 200, 2000, 20k? Higher?
    if you are still having problems ,ask sportsterdoc. he made a post before about experience in this area, check the sticky post on 'Electrical Theory'
    2005 Tdub
  1. Just checking in
    By gregfish in forum General Discussion
    Last Post: 12-01-2015, 11:27 AM
  2. Checking fork oil and setting SAG
    By Little Brute in forum Technical Help
    Last Post: 06-14-2015, 03:47 PM
  3. Setting the float...?
    By DIS-KO in forum Technical Help
    Last Post: 08-24-2014, 03:48 PM
  4. Setting Float
    By wayno in forum Technical Write-Ups
    Last Post: 02-27-2014, 06:39 PM
  5. setting an example
    By phelonius in forum Test Forum
    Last Post: 12-01-2010, 09:48 AM
