Checking a stator-What ohms setting?
Results 1 to 10 of 19
Like Tree15Likes
Thread: Checking a stator-What ohms setting?
    Senior Member Hidebound's Avatar
    Sep 2013
    Lucinda,PA
    393
    Currently chasing an electrical gremlin - oh the joy. There are lots of threads on checking the phases of a stator with a volt meter but not a one of them I can find say exactly which notch on the meter I need to be using - 200, 2000, 20k? Higher?
    '01 TW200, '03 Z1000, '09 KLR 650
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,097
    Use the lowest possible range for an accurate reading. If the expected reading will be under 200 ohms use that range.
    jtstdub likes this.
    Sep 2013
    Lucinda,PA
    393
    0.9 @ 200 is as close to the listed spec of .3 - .5 as I can read. Guess it's still good then?
    Apr 2013
    299
    what is the problem youre having?
    Nov 2016
    So. California
    202
    If the spec is .3-.5 ohms, .9 is a little high. But the error in your dmm could account for the difference. I'd look into calibrating your multimeter, not because it might wrong, bit because your lowest setting is 200. A lower setting, like 20, would make me more confident in the resistance reading I was getting.
    Fred and jtstdub like this.
    Sep 2013
    Lucinda,PA
    393
    Quote Originally Posted by supachip1 View Post
    what is the problem you're having?
    It's eating batteries. Not just draining them, but 'It's dead Jim' killing them.
    Mar 2015
    Ynys Môn
    2,406
    I presume you've checked the regulator/rectifier unit ?
    socalnative likes this.
    TW200 - 1998 - Japanese import - 5000 miles on the clock - TW225 Special Edition 2007
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    636
    If you have to put on a battery disconnect. I have one bike I went through the starter, charging system, wiring and after fixing a short still has an issue. I just turn the knob to disconnect and it works. I figured it did it on its own maybe I'll hit a bump and it will go away. Sounds good anyway.
    Fred and socalnative like this.
    Sep 2013
    Lucinda,PA
    393
    R/R tested good, but they're not horribly expensive so I ordered a new one anyway. It should be in this afternoon's mail.
    12,596
    Hope your dead battery issue is resolved.
    When I was evaluating electrical issues I found that an older style analog multimeter was more accurate and readily calibrated than newer digital meters. CATC-Appliance-Tools-Analog-Multimeter.jpg
    socalnative and jtstdub like this.
    Active Thumpers:
    2006 TW200 "Mr.Gizmo”
    1981 KDX175 Enduro
    1982 YZ250G MX
  1. Just checking in
    By gregfish in forum General Discussion
    Last Post: 12-01-2015, 11:27 AM
  2. Checking fork oil and setting SAG
    By Little Brute in forum Technical Help
    Last Post: 06-14-2015, 03:47 PM
  3. Setting the float...?
    By DIS-KO in forum Technical Help
    Last Post: 08-24-2014, 03:48 PM
  4. Setting Float
    By wayno in forum Technical Write-Ups
    Last Post: 02-27-2014, 06:39 PM
  5. setting an example
    By phelonius in forum Test Forum
    Last Post: 12-01-2010, 09:48 AM
