Engin dies on hard breaking.
Results 1 to 8 of 8
Like Tree29Likes
  • 2 Post By Brlux
  • 4 Post By elime
  • 5 Post By Fred
  • 6 Post By socalnative
  • 4 Post By Xracer
  • 2 Post By methamphetasaur
  • 1 Post By phelonius
  • 5 Post By Brlux
Thread: Engin dies on hard breaking.
    Junior Member Brlux's Avatar
    Jul 2015
    6
    So I went for a ride last night and noticed my engine would die when aggressively coming to a stop. The tank was over 3/4 full. Any thoughts on what it could be?
    Ken and jtomelliott49 like this.
    5,932
    Mine did that when the choke was partially pulled out. I pushed the choke in and all was good. The only other thing I can think of is the float isn't set correctly. Is the idle mixture screw 2 to 2 1/2 turns out?
    12,596
    Turn up the idle speed and see if problem persists.
    Active Thumpers:
    2006 TW200 "Mr.Gizmo”
    1981 KDX175 Enduro
    1982 YZ250G MX
    Nov 2016
    So. California
    202
    With the throttle closed you are completely on the idle circuit or jet. How long has it been since you rode it last? The idle jet or carb could be a little clogged.
    The motor may start fine, cold and warm, and run good but just not be able to idle with the throttle closed for a long period of time, like coming to a stop.
    But I've had this issue and it was different things every time...air cleaner, bad spark plug, carb a bit dirty.
    Start with the easy things first.
    Purple, Tweaker, Ken and 3 others like this.
    Senior Member Xracer's Avatar
    Florida
    2,875
    Perhaps a dumb question,but are you locking up the rear wheel with your hard braking?
    Senior Member methamphetasaur's Avatar
    Jun 2015
    Phoenix
    975
    Perhaps another dumb question, but could you try perhaps not braking so aggressively?
    admiral and Ken like this.
    Nov 2010
    2,146
    Open your clutch when braking that hard.
    Ken likes this.
    Phelonius
    Jul 2015
    6
    Wow, lots of good reply here, thanks. The winner is elime my choke was on.
    Thanks
    Ken, Tweaker, elime and 2 others like this.
  1. Breaking in new tw
    By Ledmelon in forum Technical Help
    Last Post: 04-21-2016, 09:17 PM
  2. Breaking The Bead.
    By TopPredator in forum Technical Help
    Last Post: 03-13-2016, 04:41 PM
  3. Swapping a 2006 engin for a 96. Wireing?
    By Dah-Mon in forum Technical Help
    Last Post: 01-19-2016, 05:01 PM
  4. Breaking Up
    By Kenny 1 in forum Technical Help
    Last Post: 07-04-2013, 12:14 PM
  5. Breaking in the new knobs
    By chainslap in forum Trails, Off-road, and Adventure Riding
    Last Post: 05-12-2013, 06:36 AM
