Differences in cylinders
Results 1 to 8 of 8
Like Tree19Likes
  • 1 Post By elime
  • 3 Post By TW-Brian
  • 1 Post By elime
  • 5 Post By elime
  • 3 Post By christddel
  • 1 Post By elime
  • 2 Post By christddel
Thread: Differences in cylinders
    5,932
    I bought 2 cylinders for future use and was looking at them today. I noticed one, I think the one advertised for an XT200, has an air passage or vent between the cam chain and the cylinder. The other, and I have no recollection what is was advertised for, doesn't have that airway. The cylinders are basically the same in all other respect that I can see (so far) and I am positive both will work on the TW engine.
    If anyone has knowledge of this, the pros and cons, please enlighten me.
    Ken likes this.
    Pleasanton, CA
    4,331
    Tony,
    I can't help you with this except to say that the two 1987 TW200, one 1992 XT225, one 199? TW200, one 2000 TTR225, one 2005 TW200, and one 2007 TW200 engines that I have do not have this air gap.
    Brian
    Ken, elime and TopPredator like this.
    site:tw200forum.com
    5,932
    Brian -- I looked at my ebay purchase history and it was advertised as an" '82 '83 XT200 cylinder." 20 bucks including shipping so no big investment. I am real sure it will work on the TW. I only wonder if it can be honed to 70mm.
    Ken likes this.
    Pleasanton, CA
    4,331
    This cylinder should make one of your bikes even faster - better cooling, less weight, less air resistance. We look forward to your new TW land speed record !
    TopPredator, elime and Ken like this.
    site:tw200forum.com
    5,932
    I am almost ready to put my parts bike with the 70mm Wiseco and MegaCycle camshaft and 14/50 sprockets and 5 speed transmission up against a TW225 with a 6 speed. Almost ready -- a little more carb tuning necessary,
    Ken, Dryden-Tdub, Fred and 2 others like this.
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    290
    Hello,
    Sorry for my translation...
    I have not yet seen this form of cylinder, It is a special edition, I know just these ...!
    Yes the cylinder of 200 XT TW; can Rebuilding cylinder (Boring) to Max 70mm
    elime, Fred and Ken like this.
    5,932
    Quote Originally Posted by christddel View Post
    Hello,
    Just for the fun of it I did an ebay search for "XT200 cylinder" and several cylinders with the air vent showed up -- all were 1982 or 1983.
    Thanks for the info on boring to 70mm. I hope there is enough metal by the vent so it doesn't break.
    Ken likes this.
    Oct 2010
    Belgium
    290
    Exactly, I have seen this too, it would be a limited series in the year 1982/83 ?
    Hello,
    The boring centering must be perfect, as it will remain +/- 1.5 mm thickness sleeve...
    I did a bore test on a cylinder block of the TW125.
    Boring to place the sleeve;
    Of the SR185 ---> OK
    Of TW200 ----> OK
    Of XT225 ----> KO, Not good ...! .. there are holes
  1. Replies: 3
    Last Post: 10-14-2015, 01:11 PM
  2. Carb differences
    By macbig2k1 in forum Technical Help
    Last Post: 01-08-2013, 01:00 PM
  3. Differences between '98 and '09
    By kenfyoozed in forum General Discussion
    Last Post: 09-25-2012, 08:10 PM
  4. carb differences?
    Last Post: 06-12-2011, 04:04 PM
