Red rear spring install issues
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Like Tree143Likes
Thread: Red rear spring install issues
    Junior Member EVH's Avatar
    Apr 2017
    14
    I bought the red 19kg spring to replace my stock rear spring. Ive taken it to 3 shops and they cant seem to compress it enough to put the collars back on. I was wondering if maybe
    Yamaha made a change to the rear shock for 17. The spring does look 2 inches longer then the stock one. I also noticed I have a different type of tension adjuster on this shock then what shows in the videos.
    DANo896, Ken and jtomelliott49 like this.
    Pleasanton, CA
    4,331
    This is the first that I have heard that the 2017's have a new shock. I am "shocked " that Yamaha actually made a change to the TW!
    Let's see some pics of that shock. It must not be an upgrade if you are looking to replace the spring already.
    I don't remember the red spring being significantly longer that the stock yellow one.
    site:tw200forum.com
    Apr 2017
    14
    I'll post some pictures tomorrow. My stock spring is black and no where near at thick as your yellow one.
    TW-Brian, Ken and jtomelliott49 like this.
    Apr 2017
    14
    Here is the shock, the black spring is the stock one. Notice the tension adjuster how its different.IMG_0228.JPG
    jtomelliott49, cowboyjeff and Ken like this.
    Senior Member Deepseadan's Avatar
    Sep 2016
    So Cal
    278
    Yeah I just did my 2016 spring and I don't remember it being that much longer than the stock spring. Your rear shock is definitely different than mine and when I look at the parts diagrams there are different part numbers for the two years. Yamaha obviously changed the shock for 2017. I know my local shop was barely able to squeeze it on and I had it on the longest setting or softest position. Bummer if you can't get it to fit, the 19kg spring was a massive improvement over stock. It's the only aftermarket spring that I know of as well. Maybe you could have cannon racecraft make you one if worse comes to worse. The procycle 19kg is straight rate.
    If it helps I just measured my stock black spring uncompressed and it measured about 7.5" tall. Is yours that same length?
    Sent from my iPhone using Tapatalk Pro
    Dryden-Tdub, Ken and jtomelliott49 like this.
    Current bikes 2016 KTM 500 EXC, 2016 Yamaha TW 200
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,097
    Quote Originally Posted by EVH View Post
    IT looks like the new shock has adjustment notches, the bottom of the pic?
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    636
    Check with Procycle, maybe they accidentally sent you a different red spring, wrong length. Maybe someone can measure a stock shock from another year. Maybe the new one is shorter.
    socalnative and jtomelliott49 like this.
    Apr 2017
    14
    Quote Originally Posted by Deepseadan View Post
    My stock spring measures 6 1/4 inches uncompressed. I don't think there's a way to make this spring fit, it looks like you'd have to compress the red spring almost entirely to get it to the point you could put the collars on. I do think they changed the shock on the 17's. So I'm now stuck with a 130 dollar spring that doesn't fit.
    Thanks for everyone's help.
    Ken, Purple and jtomelliott49 like this.
    rbm
    rbm is offline
    Jan 2011
    4,097
    I would call Procycle and explain the situation. This is the first time we've heard that Yamaha has changed something on the TW suspension since inception.
    socalnative, Ken and jtomelliott49 like this.
    Nov 2016
    So. California
    202
    Procycle should take it back because it's not the correct part. I'm not that familiar with the stock rear spring but I don't remember it being wound that progressively. The red spring would have to be compressed way to much to fit. And I'd bet it would leave you with limited travel before the coils bound.
    Call procycle before messing around more with that spring.
  1. Wanted ProCycle Red Rear Spring & 70kg Front Springs etc
    By PlacerLode in forum TW200 Classifieds
    Last Post: 04-22-2016, 02:57 AM
  2. Replies: 19
    Last Post: 06-24-2015, 12:14 PM
  3. rear drum issues
    By gamorg02 in forum Technical Help
    Last Post: 07-03-2014, 01:44 PM
  4. Rear Wheel issues...again
    By bluefox in forum Technical Help
    Last Post: 06-25-2014, 11:11 AM
  5. Headlight Assembly Spring Install...help please?
    By a_frye in forum Technical Help
    Last Post: 11-26-2013, 02:03 PM
