Carb Issue
Results 1 to 6 of 6
Thread: Carb Issue
    Junior Member JLM's Avatar
    Jul 2013
    3
    Carb Issue
    I just purchased a 1992 TW 200 that has been stored for years. The bike starts and runs well but will not idle with the choke off, runs ok with the choke pulled out. Any suggestions? Do I need to rebuild the carb or will a good cleaning do the trick?
    Junior Member SurfRider's Avatar
    Apr 2011
    29
    I have bought a few bikes that haven't run in years and usually all it takes is just cleaning the idle jet out with a piece of wire or replacing it with a new one. I would start there as it's very simple and especially if the bike runs fine off the choke once you roll on the throttle more than a 1/4 turn or so.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,069
    Check your pilot jet, mine was the same as yours, the pilot was the culprit.
    Spokane, Washington
    14,137
    Try some "Lucus Deep Fuel Cleaner" first, has worked wonders on a couple of my bikes without having to open the carb.
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Just got done with my brother's bike. It had exactly the same problem, and as the others said it was the pilot jet clogged up. The only way I could unclog it was to soak in some carb cleaner, then run a piece of wire from a wire brush through it. Be aware that the actual hole in the jet is much smaller than the hole appears from either end. A wire from a wire brush is small enough and stiff enough to do a good job. His bike runs great now, and I'm sure yours will too once you get it cleaned up.
    Jul 2013
    3
    Thans for all the info.
  1. First TW. Hot Start Issue
    By Qicker306 in forum Technical Help
    Last Post: 06-11-2013, 06:17 PM
  2. Clutch issue
    By Wyatt570 in forum Technical Help
    Last Post: 06-05-2012, 01:43 PM
  3. Old carb question/issue
    By Boarder255 in forum Technical Help
    Last Post: 05-27-2012, 04:47 PM
  4. Front sprocket issue
    By SRTeric in forum Technical Help
    Last Post: 06-07-2011, 11:36 AM
  5. 91 tw charging issue
    By mike438 in forum Technical Help
    Last Post: 03-13-2011, 08:25 PM
