High compression, wont take throttle
Results 1 to 5 of 5
    Senior Member mtkd's Avatar
    Feb 2012
    NY
    215
    Now this sounds like a fuel problem right off the bat. I have cleaned the car multiple times and it is as clean as it can get.
    I have 190PSI compression (way too high)
    Valve lash is in spec, verified twice
    Fuel is good,
    New spark plug that does spark
    Bike turns over and will idle ok. Enrichner will raise idle. Turning the throttle kills the bike.
    Anyone have any ideas?
    -Szj
    2001 TW
    Spokane, Washington
    14,134
    I would double check the compression with another gauge first. Was the old plug black, fouled or rich? Were you running higher than 87 octane in it? Air filter clean and oiled? How about a half turn or more in on the mixture screw to see if it might have been too rich, and also trying the other way out on the screw to richen it if the plug hadn't looked to black and/or rich?
    Aug 2011
    Cayce, SC
    3,109
    First off you need to find out why your compression is so high. Is the piston and head covered with carbon deposits? Are you sure that you are setting your valves correctly? Many people dont understand how to use feeler gauges. Did you install a high compression piston? You will only be band-aiding the problem until you figure out why the compression is so high.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Senior Member rurlndum's Avatar
    Jun 2013
    447
    I am a firm believer in the k.i.s.s. (keep it simple stupid) principle.
    I think your carburetor slide is stuck.
    Feb 2012
    NY
    215
    The bike was running rich and the plug was brown black. This was a working gauge, and had been used earlier in the day and after I used it. Was running 87 octane.
    As for the air filter, that reminds me, there was a lot of engine oil in the air box and in the filter. Oil was clean. Have since tried to run it without the air filter.
    -Szj
    2001 TW
  1. What should engine compression be at?
    By Beewerks in forum Technical Help
    Last Post: 10-23-2013, 06:45 PM
  2. High Compression?
    By Boarder255 in forum Technical Help
    Last Post: 08-19-2013, 06:18 PM
  3. Compression check
    Last Post: 04-29-2013, 06:13 PM
  4. Finding the Compression Ratio
    By ronnydog in forum Technical Help
    Last Post: 12-09-2012, 04:21 PM
  5. Compression Test
    By Henrici in forum Technical Help
    Last Post: 09-27-2010, 02:58 PM
