Spark Plugs
Poll: Spark Quiz
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 10 of 19
Thread: Spark Plugs
    Senior Member rm_hm's Avatar
    1,619
    [media]http://www.youtube.com/watch?v=6GiIVze2Tac&feature=related[/media]
    Just wanted to see what our diverse group of folks are using.
    What group do you fall into ?
    We have The Stock Spark Plug Users
    NGK DR8EA
    Champion RA6HC
    AC Delco S102F (Double Check)
    Autolite 2796 (Double Check)
    The Iridium Plug Users ( lots of folk report easier starting)
    Denso IX24 &
    IXU01-24
    NGK DR8EIX & DR8EVX (correct me if I'm wrong)
    Other Plug Types
    Pulstar
    Brisk Performance Spark Plugs #1886yBR12ZC1886yz (Sold @ amazon.com)
    Over on the Yamaha R1 forum they report that these plugs make their pipes run a lot hotter.. It was a tossup with people liking and dis-liking them
    The E3 Spark Plug Users #E3.36 Link To Old Thread
    I've heard that this plug runs hot for some. Others say the huge tip acts like a glow plug and caused detonation. And just a couple of others that had the tips break off and or melt.
    I use them in my RV90 and all my two stoke equipment and am really pleased with them. I don't use them in the TW since they take a different size socket and I don't want to have to pack two spark plug wrenches.
    The Spark Enhancers
    IKAT Spark Enhancer Is now Booster Motorsports AKA ibooster
    Pulstar DirectHits "ultra High-Power spark amplifier"
    (Must be used with a non resistor plug like E3.36 Or NGK D8EA)
    Product Claims
    • Greater engine torque up to 9%
    • Greater horsepower up to 7%
    • Quicker throttle response
    • Better fuel economy up to 10%
    • Lower emissions across the board reductions
    • Smoother operation
    • Enhanced driving experience
    • Easier starting
    Some folks have taken out the tiny resistor in the spark plug cap and replaced it with a bit of copper, brass or stainless.
    Link To Every Thread Regarding Spark Plugs And Such (Past and present)
    http://www.google.co...f&aqi=&aql=&oq=
    Disclaimer::: Cross reference is provided as a convenience only. Due to differences in design and material, plugs produced by various manufacturers may not have exactly the same heat range nor firing point configuration. I recommend use of manufacturer search for a specific plug application before you buy.
    10,665
    Poll doesn't work for me. 3rd question needs "To each his own." option.
    Champion Powersports plug from Walmart. No enhancers. To each his own (waste of money).
    1,619
    Edit: 07/28/2012
    Updated a little and fixed question choices for Qwerty
    Senior Member FnMag's Avatar
    493
    I believe I have the NGK DR7xx in mine...
    Starts on 2nd or 3rd kick (if I remember to turn on the kill switch)
    The Southwest
    535
    It's been almost a year since the last post. How about a bump?
    2012 TW200: Cyclerack Rear Rack ... Cyclerack Bag Supports ... Jimbo Cafe Shield ... Pro-Taper ATV High Bars ... Tusk D'Flex Hand Guards ... Tusk Hand Mitts ... Tusk Grip Heaters
    493
    Same plug in mine, haven't changed it. I've done less than a 1000 miles this past year with all my neck issues (bulging disc).
    I pulled it recently and it looked fine. A little on the dark side, but it came off easy with a brass brush.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,419
    I followed Babaganosh's lead when he presented the Ikat/Directhit. I put the Ikat on my Baja Bug and cold start issues with my choke-less duel ICT's went from annoying to a non-issue. Not only did the engine start instantly. Should I be so inclined, I could get that little 4 cylinder to idle smoothly down to 500 rpm and it would transition without hesitation. A hardy thumbs-up on this product.
    Got the Direct-Hits for the TW. As my bike was pretty new every thing seemed ok. Like many of us I was a bit annoyed with the need to choke and warm-up when things got chilly. The Direct Hits seemed to help with this in the beginning. Now I am not sure it does anything, but then my bike has been modded so much it is hard to say what if anything is working less than 100%. Gerry
    Take care my Friend.........
    1,619
    About time for a
    Senior Member indika666's Avatar
    Dec 2013
    Colombo, Sri Lanka
    109
    Anyone run with the NGK DPR8EA-9 ?
    I coudn't find DR8EA, so the vendor suggested to use this..! Is it OK?
    2006 TW200E (JDM) -> 100% stock, Shinko SR428 front, Bridgestone TW204 rear, 14/45 stock gearing
    Senior Member Hoot Gibson's Avatar
    Dec 2013
    Grand Lake Ohio
    4,039
    Frankly not sure what came with the new 2014 tw.... With still only 70 some miles on it, I have not even checked....but I did purchase 2 spares from Auto Zone and they come up with NGK D8EA....guess the less letters/numbers the better
    Hoot's Ride Slide Show Music Videos
    TW Adventure Rides Completed
    March 2015 Moab: With 30 TW Forum Friends..
    Summer 2015 Great Lakes, Wisconsin, UP of Michigan, With Borneo and Montezuma
    November 2015: SE Ohio/West Virginia w/ Borneo and Montezuma
    March 2016: Big Bend NP in South Texas w/ Montezuma, Borneo, Ebbanflood and FW Gary
    August 2016: Montezuma and Hoot's Covered Bridge Ride in Southern Indiana
  1. Second opinion on spark plugs
    By BoatHands in forum Technical Help
    Last Post: 03-19-2013, 04:04 PM
  2. Spark Plugs stock vs. iridium
    By aztw200 in forum General Discussion
    Last Post: 10-26-2012, 05:17 AM
  3. Spark plugs
    By Delboy in forum Technical Help
    Last Post: 09-10-2012, 05:50 PM
  4. Replies: 2
    Last Post: 07-21-2012, 12:44 AM
  5. Spark Plugs
    By Two Shoes in forum TW200 Classifieds
    Last Post: 08-02-2010, 02:21 AM
1994 yamaha tw 200 spark plug gap
d8ea e3
how often to change spark plug tw200
ngk d8ea to e3
tw200 best spark plug
tw200 plug gap
tw200 spark plug
tw200 spark plug gap
tw200 spark plug torque
yamaha tw200 spark plug
yamaha tw200 spark plug gap
