Yamaha TW200 Trailway Discussion Forum: Spark Plugs - Yamaha TW200 Trailway Discussion Forum
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Spark Plugs Reviving an old topic
Poll: Spark Quiz
This is a public poll. Other members will be able to see which options you chose
What Plug Do You Use
You cannot see the results of the poll until you have voted. Please login and cast your vote to see the results of this poll.
Do You Use A Spark Enhancer
Have You Had Problems With Any Of These?
If you took your plug out what would it look like
Vote Guests cannot vote
#1 User is offline   Rich
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationNear Narrows Bridges, WA State
Posted 14 November 2010 - 01:57 AM
Just wanted to see what our diverse group of folks are using.
What group do you fall into ?
We have The Stock Spark Plug Users :D
NGK DR8EA
Champion RA6HC
AC Delco S102F (Double Check)
Autolite 2796 (Double Check)
The Iridium Plug Users Posted Image ( lots of folk report easier starting)
Denso IX24 &
IXU01-24
NGK DR8EIX & DR8EVX (correct me if I'm wrong)
Other Plug Types
Brisk Performance Spark Plugs #1886yBR12ZC1886yz (Sold @ amazon.com)
Over on the Yamaha R1 forum they report that these plugs make their pipes run a lot hotter.. It was a tossup with people liking and dis-liking them
Posted Image
The E3 Spark Plug Users #E3.36 Link To Old Thread
Posted Image
I've heard that this plug runs hot for some. Others say the huge tip acts like a glow plug and caused detonation. And just a couple of others that had the tips break off and or melt.
Posted Image
I use them in my RV90 and all my two stoke equipment and am really pleased with them. I don't use them in the TW since they take a different size socket and I don't want to have to pack two spark plug wrenches.
The Spark Enhancers Posted Image
IKAT Spark Enhancer Is now Booster Motorsports AKA ibooster
Pulstar DirectHits "ultra High-Power spark amplifier"
(Must be used with a non resistor plug like E3.36 Or NGK D8EA)
Product Claims
  • Greater engine torque – up to 9%
  • Greater horsepower – up to 7%
  • Quicker throttle response
  • Better fuel economy – up to 10%
  • Lower emissions – across the board reductions
  • Smoother operation
  • Enhanced driving experience
  • Easier starting
iBOOSTER http://www.boostermo...s.com/index.php
Product Claims
- Increase's power under load
- Improves throttle response
- Reduce Engine operation temperature
- Reduce fuel consumption
- Reduce exhaust emissions
- Increase torque and responsiveness
Some folks have taken out the tiny resistor in the spark plug cap and replaced it with a bit of copper, brass or stainless. :blink:
Link To Every Thread Regarding Spark Plugs And Such (Past and present)
http://www.google.co...f&aqi=&aql=&oq=
Disclaimer::: Cross reference is provided as a convenience only. Due to differences in design and material, plugs produced by various manufacturers may not have exactly the same heat range nor firing point configuration. I recommend use of manufacturer search for a specific plug application before you buy.
0
#2 User is offline   qwerty
  • Big Dummy
  • PipPipPip
  • Group: Members
  • LocationNW Tennessee
Posted 14 November 2010 - 03:41 PM
Poll doesn't work for me. 3rd question needs "To each his own." option.
Champion Powersports plug from Walmart. No enhancers. To each his own (waste of money).
After watching a king snake and a rat snake fight to the death, the best thing to do is walk away and leave the king snake to enjoy his dinner.
0
#3 User is offline   Rich
  • Advanced Member
  • PipPipPip
  • Group: Members
Posted 31 January 2011 - 12:06 AM
Edit: 07/28/2012
Updated a little and fixed question choices for Qwerty Posted Image
0
#4 User is offline   Mike
  • Member
  • PipPip
  • Group: Members
Posted 17 October 2011 - 08:31 PM
I believe I have the NGK DR7xx in mine...
Starts on 2nd or 3rd kick (if I remember to turn on the kill switch)
0
#5 User is offline   retmotor
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationWestern Montana
Posted 31 August 2012 - 09:00 PM
It's been almost a year since the last post. How about a bump?
2012 TW200: Cyclerack Rear Rack ... Cyclerack Bag Supports ... Jimbo Cafe Shield ... Pro-Taper ATV High Bars ... Tusk D'Flex Hand Guards ... Tusk Hand Mitts ... Tusk Grip Heaters
0
#6 User is offline   Mike
  • Member
  • PipPip
  • Group: Members
Posted 31 August 2012 - 09:04 PM
Same plug in mine, haven't changed it. I've done less than a 1000 miles this past year with all my neck issues (bulging disc).
I pulled it recently and it looked fine. A little on the dark side, but it came off easy with a brass brush.
0
#7 User is offline   mrgizmow
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationParadise, Calif.
Posted 31 August 2012 - 10:45 PM
I followed Babaganosh's lead when he presented the Ikat/Directhit. I put the Ikat on my Baja Bug and cold start issues with my choke-less duel ICT's went from annoying to a non-issue. Not only did the engine start instantly. Should I be so inclined, I could get that little 4 cylinder to idle smoothly down to 500 rpm and it would transition without hesitation. A hardy thumbs-up on this product.
Got the Direct-Hits for the TW. As my bike was pretty new every thing seemed ok. Like many of us I was a bit annoyed with the need to choke and warm-up when things got chilly. The Direct Hits seemed to help with this in the beginning. Now I am not sure it does anything, but then my bike has been modded so much it is hard to say what if anything is working less than 100%. Gerry
Take care my Friend.........
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
